It is currently Sat Nov 30, 2024 7:48 pm
 Post subject: Towel marks from waxing
PostPosted: Tue Nov 15, 2016 4:26 pm
City: London
State: ON
Zip/Postal Code: N6C5Y2
I'm a beginner in terms of refinishing guitars, electric specifically.
My issue is after wet sanding the laquer clear coat down to 2000, I then applied wax.
I applied it by hand on both sides but somehow the towel that the guitar was resting on as I waxed has made an impression fairly deep into the finish.
Was heat the cause?
Should the guitar not be flat on a clean towel when buffing/polishing?
The good news is on a test guitar I got my technique down when I changed to compounds and omitted wax but I'm worried about making the same mistake again.
So I saw what happened but not sure why.
Thanks.
PostPosted: Tue Nov 15, 2016 5:51 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
What kind of wax, Paul?
Alex
PostPosted: Tue Nov 15, 2016 6:23 pm
City: London
State: ON
Alex
Mothers carnauba wax
PostPosted: Tue Nov 15, 2016 7:03 pm
First name: Dan
Last Name: Smith
City: Round Rock
Zip/Postal Code: 78681
Sounds like the finish was not hard yet.
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Nov 15, 2016 7:08 pm
City: London
State: ON
I wondered about that. I let it hang for 6 weeks but I did put a lot of coats on.
PostPosted: Tue Nov 15, 2016 8:42 pm
First name: Alex
Last Name: Kleon
City: Whitby
Could there have been some solvent on the towel? That could soften the wax, even if there's a hint of it.
Alex
PostPosted: Tue Nov 15, 2016 10:35 pm
City: London
State: ON
Alex
I don't think so but now that I think about it, it was an old towel. I'll test a small area with a different towel. Thanks.
PostPosted: Wed Nov 16, 2016 7:45 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
What brand and type of finish?
Brian
PostPosted: Wed Nov 16, 2016 8:48 am
City: London
State: ON
Duplicolor clear coat.
PostPosted: Thu Nov 17, 2016 8:11 am
Last Name: Howard
City: Magnolia
State: Delaware
Not to familiar with the duplicolor stuff but I have seen issues with other rattle can brands (most notoriously Deft) Taking months to harden and then never really achieving the hardness I would expect of a nitro lacquer.
Brian
PostPosted: Thu Nov 17, 2016 8:31 am
City: London
State: ON
Yeah this is possible too. I'm going to wet sand and buff with compound and see where it gets me. Thanks.
Edit: I think it's not hard. I haven't come across a hardness test but I noticed someone in another forum said to check if you fingernail can make a dent. Well mine did, I went easy so it's not deep but looks like I'm going to have to keep waiting.
Is there a repair procedure for clear coats? Could I take it to a professional shop and have them add a few coats? The paint job is rather intricate, I would rather not start that over. :shock:
PostPosted: Fri Nov 18, 2016 8:11 am
Last Name: Howard
City: Magnolia
State: Delaware
IME the only solution is to remove the soft lacquer and re-finish. If you put a harder coating over a softer one it will crack and peel....
Brian
PostPosted: Fri Nov 18, 2016 8:43 am
City: London
State: ON
So just sand down to the paint?
PostPosted: Mon Nov 21, 2016 11:10 am
First name: Rob
Last Name: O
It's going to be extremely hard to not sand through - I usually chemically remove nitro. what did you paint it with?
Check out some of my tunes! http://soundcloud.com/rockinrob86
